ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
May 06, 2019Guru - Experienced User
Lets see what version of FW is loaded first. He may be on a old version which may not work for him until he gets it more up to date or there is a NG service issue or possible ISP modem issue. Lets find out first what he's got going currently.
swall101
May 06, 2019Aspirant
Screenshot attached...... latest firmware and works perfectly on both router and satellite.
- Pedro_mustardMay 06, 2019Aspirant
to get to 2.3.1.48 I had to email the CEO of Netgear otherwise I would not get support then I got a call from netgear technical and they had to download from the website and put on both devices but as of yet 60 is not listed yet.
- FURRYe38May 06, 2019Guru - Experienced User
What browser are you using?
I use my own router with the setup I have it's a BiPAC 8800NL latest firmware, no I never was sent an ISP router and it's not a router fault.
