ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
May 06, 2019Guru - Experienced User
We believe NG disabled AutoUpdate at v32/v44 and beyond. However the system still queries NG update servers and lets users know if there is a FW update available. So from now on, users can pick if and when they want to update Orbi FW thru the FW update feature on the RBR.
Joboo7777 wrote:
Has anyone received .60 through the auto update process? I’m on .44 and have not received .48 and now .60 through auto updates.
tagteam
May 06, 2019Virtuoso
Yes...........much, much better. I noted that 2.3.1.60 just sat there doing nothing every time I checked. I had to click Update All before the new version was applied which is absolutely ideal - finally!
