ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
Joostvanderpost
May 06, 2019Aspirant
I am tired now of trying so leaving 2.2.1.112 on it for now... hoping it is stable... mayby another day I will try again with your advice. Thanks
gr8sho
May 06, 2019Virtuoso
That's good if it works and the RBK50 doesn't autoupdate itself. Did you use the manual method of disabling auto update?
