ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
gr8sho
May 06, 2019Virtuoso
It should, yes. The recommendation above your last post suggested disabling wifi on the host router. The host router would still have its DHCP server running to handle address assignments to your devices connected to the Orbi.
Also worth noting that in some Fiber installations, ISP routers can be bypassed and have the Orbi connected directly to the ONT. This would allow the Orbi to run in its native router mode.
michaelkenward
May 06, 2019Guru - Experienced User
Not essential.
I don't. But I have different SSIDs on Orbis and router and I am careful about pointing wifi clients at the right SSID.
- gr8shoMay 07, 2019Virtuoso
michaelkenward wrote:
Not essential.
Are you able to control channels to avoid overlap/conflict? Most would not know how to do this and if they left all the radios active and things were acting strangely, would make troubleshooting more complex.
I do enjoy the benefits of single wireless network and assumed most owners would use the Orbi to be their sole wireless system.
- Christian_WMay 08, 2019Star
Just updated my system to Firmware 2.3.1.60 and everything worked just fine.
No hickups during upgrade or something like that.
Backhaul status is showing status "good" and everything looking good so far.
- FURRYe38May 08, 2019Guru - Experienced User
Thank you for letting us know. Enjoy. :smileywink:
