ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
Blanca_O
May 06, 2019NETGEAR Employee Retired
The firmware 2.3.1.60 has the following changes :
Fixes the issue where the time zone can't sync with the satellite
Fixes issues with the guest network control using Alexa
Includes security fixes
JMU1998
May 07, 2019Luminary
After updating to. 60 now my sattalite shows up as connected as a 5g eventhough it has an Ethernet cable plugged in connected to my network. Did factory reset on both sattalite and main unit running in AP mode. Anyone else seeing the sattalite showing as 5g instead of wired for those using wired backhaul and did latest update?
- FURRYe38May 07, 2019Guru - Experienced User
Did you first add the RBS to the RBR via wiress first, then connect the RBS via LAN cable to the RBR? Need to wait about 5 minutes before the BLUE led comes up. Be sure Daisy Chain is disabled before starting the setup process.
What is the Mfr and model# of the ethernet switch if one is in the configuration.
- JMU1998May 07, 2019Luminary
Yes added the RBS to the RBR main unit via wireless and it connected Daisy Chain is off the switch is a Netgear R8000 switch and when I connect to ethernet RBR shows the RBS connected as 5g instead of wired.
What happens if you remove the R8000 from the mix and directly connect the satellite to the RBR?
Is the R8000 configured for LAN to LAN AP mode with it's wireless disabled?
