ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
JMU1998
May 07, 2019Luminary
Yes added the RBS to the RBR main unit via wireless and it connected Daisy Chain is off the switch is a Netgear R8000 switch and when I connect to ethernet RBR shows the RBS connected as 5g instead of wired.
May 07, 2019Guru - Experienced User
What happens if you remove the R8000 from the mix and directly connect the satellite to the RBR?
Is the R8000 configured for LAN to LAN AP mode with it's wireless disabled?
