ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
michaelkenward
May 05, 2019Guru - Experienced User
Maybe there isn't one. They don't always go side by side, especially for satellites.
gr8sho
May 08, 2019Virtuoso
Although most have probably figured this out by now, the RBS50 does indeed have a .60 update. Cheers.
