ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
Christian_W
May 08, 2019Star
Just updated my system to Firmware 2.3.1.60 and everything worked just fine.
No hickups during upgrade or something like that.
Backhaul status is showing status "good" and everything looking good so far.
May 08, 2019Guru - Experienced User
Thank you for letting us know. Enjoy. :smileywink:
