ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
May 08, 2019Guru - Experienced User
For everyones knowledge. NG has now posted the v60 FW update files for manual download. This is for the 50 series Orbi systems. RBR and RBS only.
https://www.netgear.com/support/product/RBK50.aspx#download
Enjoy. :smileywink:
