ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
May 09, 2019Guru - Experienced User
The RBR I have is working nicely on this version. :smileyvery-happy:
gr8sho
May 11, 2019Virtuoso
I updated from .44 using web GUI and the standard method offered there. I also cold started both devices afterwards for good measure. I’ll probably also factory reset at some point as well to see if WiFi performance improves, to clear NVRAM changes I made, and to validate if auto updates are truly fixed.
