ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
May 15, 2019Guru - Experienced User
Looks like you have solved your issue here:
cdnSpinalTap wrote:
I'm having the same issues with 2.3.1.60 - basically dead in the water. Details in this thread here.
Anyone have additional suggestions?
cdnSpinalTap
May 15, 2019Guide
Yes, thank you.
- FURRYe38May 15, 2019Guru - Experienced User
Be sure to save a new backup configuration to file for safe keeping.
Enjoy.
cdnSpinalTap wrote:
Yes, thank you.
