ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
Hamstar
May 15, 2019Guide
On my Orbi RB50 router with 2 satellites, I am running firmware v2.3.1.48 and v2.2.1.60 was dowloaded and sitting in the status box for the router and both satellites. I do not want to install that just yet. How do I prevent that?
May 16, 2019Guru - Experienced User
You don't have to update. The updates are just there and available for you. You have to make the update happen. NG no longer forces auto FW updates.
