ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
JMU1998
May 28, 2019Luminary
Why does Sattalite show me the exact same attached devices list as main unit? anyone else experiencing this issue? It was not like this before taking 60 Firmware. I have done multiple factory resets with nvram wipe on both main and satellite and multiple reboots and manually input all info. absolutely nothing else has changed in my setup or environment other than taking 60 Firmware and additionaly sattalite shows as 5g which is incorrect as it is wired. Reverted to previous Firmware and none of the above mentioned issues encountered so what has changed in 60 to cause these issues? Using AP mode. Have wasted hours!
May 28, 2019Guru - Experienced User
Daisy chain disabled?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
JMU1998 wrote:Why does Sattalite show me the exact same attached devices list as main unit? anyone else experiencing this issue? It was not like this before taking 60 Firmware. I have done multiple factory resets with nvram wipe on both main and satellite and multiple reboots and manually input all info. absolutely nothing else has changed in my setup or environment other than taking 60 Firmware and additionaly sattalite shows as 5g which is incorrect as it is wired. Reverted to previous Firmware and none of the above mentioned issues encountered so what has changed in 60 to cause these issues? Using AP mode. Have wasted hours!
