ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
Kammen77
Jun 02, 2019Aspirant
I also have the surfboard SB6141 AND AN COMCAST I have the some of the same things happening, I have unplugged the way cable and the icon on the modem stays flashing as connected. I am starting to wonder if the modem has something to do with it.
Jun 03, 2019Guru - Experienced User
What is happening? A more detailed description would be needed to describe your problem.
Try a different modem?
Contact your ISP and have them check signal and services up to the modem.
