ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
Jomby
Jun 12, 2019Aspirant
So after reading through the bulk of the posts in this thread, I am thinking best to stay with 44 since it has been quite solid and it is doing all that I need. I don't want to hear the family screams like I did when I tried those baby orbi's . I think an early post of just waiting it out until an eero set show up at Costco is the way to go.
Jun 14, 2019Guru - Experienced User
V60 is working well for me. There are some that have issues however this is mostly either a configuration issue or after doing a FW update a factory reset and setup from scratch IS needed. This has helped many with getting systems back online after doing a FW update. There are other factors that can cause problems as well.
Jomby wrote:So after reading through the bulk of the posts in this thread, I am thinking best to stay with 44 since it has been quite solid and it is doing all that I need. I don't want to hear the family screams like I did when I tried those baby orbi's . I think an early post of just waiting it out until an eero set show up at Costco is the way to go.
