ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
skennedy789
Jun 17, 2019Aspirant
Just updated to this firmware and all Mac, iOS, PC, and smart devices in the household are occasionally dropping the WiFi signal since then. :(
- FURRYe38Jun 18, 2019Guru - Experienced User
Try a factory reset on the entire system and setup from scratch.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
skennedy789 wrote:
Just updated to this firmware and all Mac, iOS, PC, and smart devices in the household are occasionally dropping the WiFi signal since then. :(- skennedy789Jun 18, 2019AspirantThanks, I’ll try out the suggestions. The system had perfect, stable, and fast coverage for months before the firmware update, so I don’t think it’s an issue with the spatial setup.
Just checking as we don't know what configuration you have had running. Reason for the questions. Let us know how it turns out after the reset.
- RebelDadJun 27, 2019Star
Yep. I'm now having the same issues with various devices losing connectivity and having to reboot them. Going to downgrade until I see an update that seems to be smooth.
- petesaundersJun 27, 2019Star
In my case the orbis go purple and drop everything. No access through orbi admin or telnet. I have to power cycle the rbr. It will stay up for 24-48 hours then boom, same crap.
Just ugh....
It's probably a buffer overflow or something similar. Due to incompetent coding.
- FURRYe38Jun 27, 2019Guru - Experienced User
Was the FW loaded via auto update or manually? If auto update, try a manual re-load with downloaded FW files. Factory reset and setup from scratch.
I've had zero issues with v60. So have others after doing a factory reset.
RebelDad wrote:Yep. I'm now having the same issues with various devices losing connectivity and having to reboot them. Going to downgrade until I see an update that seems to be smooth.
