ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
Jun 27, 2019Guru - Experienced User
No, just needs a factory reset and setup from scratch. Mines been working since day one of installing v60.
petesaunders
Jun 27, 2019Star
So by design, these things auto update FW that requires you manually download the same FW, manually install and factory reset?
Unaccpetable.
Stop proclaiming the FW is good if you need to hospitalize the damn thing and care for it to nurse it back to health.
Please, wow.
- FURRYe38Jun 27, 2019Guru - Experienced User
Works for others. I've had zero issues since installation my self. Maybe give it a try. If not, good luck then.
- petesaundersJun 27, 2019Star
You are missing the whole point of the issue.
You should not have to manually download, install, factory reset, reconfigure.
All this AFTER an auto update borks it!
Serioualy the fastest way for me to fix this is go back to the old FW which was working fine.
FOR SALE:
1x RBR50
1x RBS50
1x RBW30
SLIGHTLY USED
SLIGHTLY WORKING
AS-IS
