ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
Gebla
Jul 09, 2019Apprentice
All you mentioned is tried already, most satellites are wired connected to the router.
It would be good if i can get some log files analyzed to explain why i see 5 ghz errors instead off just trying to fix the issue by asking end users to experiment.
Jul 09, 2019Guru - Experienced User
What is the distance between the router and satellite(s)?
How are the satellites connected to the RBR? Directly or thru a LAN swtich?
Daisy Chain needs to be disabled if ethernet connected.
You'd need to factory reset and setup from scratch and use default single SSID configuration to help determine if this is a configuration, FW or HW issue.
