ReallyAnnoyedAF
May 02, 2019Star
Orbi Firmware 2.3.1.60
Welp, anyone have any notes on this thing? It's already downloaded to my router and satellite waiting for me to pull the pin.
- May 03, 2019
Hi,
Just for information, when you're in the Firmware Update page and it downloads new firmware to install, the version number next to both the router and the satellite is a clickable link.
If you click the link, it will show you the release notes of all changes between your currently installed firmware and the update.
Although, this "feature" is not hidden, it's not always obvious that it's there either.
Jul 12, 2019Guru - Experienced User
Enjoy.
petesaunders wrote:I'm went back to .44 with telnet firmware update lock and it's been up 100% since.
I'm not going to futz with anything for a long time I was just interested to see if this new revision magically fixed it for those experiancing these stupid problems.FURRYe38 wrote:Loaded yesterday via auto update user selectable upgrade. When online today as main host router. RBS is wired backhaul. No issues seen so far. Internet speeds are to spec. Factory reset and setup from scratch was performed as other testing I did with the system required a reset.
petesaunders wrote:2.3.5.30 is out.
Anyone on this already that had issues and is it more stable?
Lsuwhodat
Jul 19, 2019Aspirant
Update:
The hurricane did not blow me away.
So I unplugged the satellite and set the Orbi up with a fresh install. I even changed the cat going to the Orbi just in case. Went through setup and all went well for about 4 days. After the trial I went ahead and manually uploaded the firmware to the satellite and set it up with wireless backhaul. So far we are on day 4 or so and it’s working smooth. Thanks all!
- FURRYe38Jul 21, 2019Guru - Experienced User
Glad your still around. It's hot were I'm from. Hehe.
Glad the system is working well now. Enjoy. :smileywink:
Lsuwhodat wrote:
Update:
