bofenstein's avatar
Nov 01, 2019
Orbi Firmware 2.5.0.38 slow
I just updated my Orbi RBR50 router and satellite to Firmware 2.5.0.38, and my Internet connection reliablity and speed were horrible.  Prior to the update, I was consistently seeing Download speeds of 230 Mbps and Upload speeds of 22 Mbps.  After the update, speeds were all over the place, with Download under 80 Mbps, and Upload around 5 Mbps.  Plus reliability of the Internet connection was very poor.
I just rolled back to 2.3.5.30, and everything is back to normal, with speeds back to 230 down and 22 up.
Is this a known issue with 2.5.0.38?  I won't be updating firmware again until the next release.
  • Retired_Member's avatar
    Retired_Member
    bofenstein wrote:
    Is this a known issue with 2.5.0.38?- Yes
    You'd be better served to NOT upgrade manually at all.  Enjoy your working system.  You'll sleep better at night.  Cheers.
  • FURRYe38's avatar
    Factory reset the system and setup from scratch. Saw no speed issues with v38 loaded.
    https://community.netgear.com/t5/Orbi/ORBI-RBK50-RBS50-Tips-Tricks-Hidden-Secrets-etc/m-p/1818889/highlight/true#M74523
      Retired_Member
      resets best for lost passwords.....
      • wchp's avatar
        wchp
        Luminary
        @wchp wrote:
        On a 2018 Macbook Pro on Firmware V 2.5.0.38 I am experiencing ½ to ¼(or less) the 802.11AC throughput vs. the previous version of firmware.
        460-585 mps on 2.3.5.30 from Mac OS wifi details and 520/41.2 from Speedtest app
        40-180 mbps on 2.5.0.38from Mac OS wifi details and 86/23.9 from Speedtest app
        Observed using WiFi details AND WiFi explorer.
        Both observations on WiFi Explorer show Chan 48, 90% signal strength, SNR 54dB readings with both versions of firmware.
        Laptop and Router locations unchanged.
        Tried everything except factory reset/paper clip simply because I dont want to and dont feel I should need to with a public firmware release (with beta firmware versions this is a given that a factory reset is done)
        Of note (if it makes any difference) I am running the Armor protection on the RBR (for both tests).
        Have reverted back to 2.3.5.30 and will wait for next rev of FW.
        OK... finally decided to give a hard reset a try.
        1) Upgraded from 2.3.5.30 to 2.5.0.38 (Tested and till same speed issue)
        2) Applied Hotfix 2.5.0.40 (tested and still same speed issue)
        AND STILL exactly the same problem.
        3) Paperclip reset the router and both Satallites from scratch
        Exact same problem still as listed above making NO changes to the factory config other than the firmware rev.
        4) Manually entered my standard config.
        Still:
        "460-585 mps on 2.3.5.30 from Mac OS wifi details and 520/41.2 from Speedtest app
        40-180 mbps on 2.5.0.38from Mac OS wifi details and 86/23.9 from Speedtest app"
        SO... went to Costco and purchased a brand new RBK53S system
        1) Upgraded from 2.3.5.xx (firmware it shipped with) to 2.5.0.38
        3) Tested WiFi speed and same poor performance on new system as my old one.
        3) Downgraded the NEW RBK53S system to 2.3.5.30 AND... silly thing, WiFi speeds and connectivity back to normal.
        I dont see a hard reset resolving the performance issues that are presenting themselves in my environment (CM-1100 --> RBK53)
        with either my 1 year old RBK53 or a brand new RBK53S
        I dont have PC or Android devices to test with but the WiFi slowdown is significant on my 2018 Mackbook Pro and iPhone Xs.
        Model: RBK53|Orbi AC3000 Tri-band WiFi System
