tdroz1
Mar 13, 2020Aspirant
Orbi Firmware Beta Testing
I'm interested in beta testing Orbi firmware if you're still looking for testers.
Thanks,
Tim
- Retired_Member
Nice
Most of the folks who do manual firmware updates end up feeling like a beta tester
- tomschmidtVirtuoso
Not just manual updates, but auto-updates prior to v2.3.x where they turned it off. And we were Alpha testers for v2.5.0.x, which broke just about everybody!
- Retired_Member
tomschmidt wrote:Not just manual updates, but auto-updates prior to v2.3.x where they turned it off. And we were Alpha testers for v2.5.0.x, which broke just about everybody!
That would be just manual updates TODAY. Auto is suppose to be those that contain crtical updates and possibly the bugs worked. And yes I was around when all the whiners complained about NG basically pushing everything. "Oh you broke my system" Today, it's the same chant, however, now it's the whiner him/herself who only have themselves to blame.
What I've not heard is how any of the whiners today update their system? The acted as they had some sort of insight of which was the best FW to update to. Really? Good luck with that.
You can join the beta forum if you like to gain access to it. Contact Christian_R
Though there hasn't been any betas for a while for Orbi AC.
You can also give Voxels FW a try if you like:
Good Luck.
tdroz1 wrote:I'm interested in beta testing Orbi firmware if you're still looking for testers.
Thanks,
Tim
