Aydo
Jun 14, 2019Tutor
Orbi Firmware Check Error
My parents have the RBK50 purchased from Costco. It hasn’t had any issues other than the initial firmware update issues. When I visited a few months ago I manually updated the firmware to 2.3.1.44 whi...
- Jun 16, 2019[continued from my previous post]
I confirmed the RBR50 and RBS50 are on 2.3.1.60. Oddly enough, the web interface checks the firmware and reports that there is no newer firmware, yet the Orbi app still gives a firmware check error.
The firmware update was done through the web interface on an iPhone in Safari.
Aydo
Jun 16, 2019Tutor
Thank you for your help. I had my father log into orbilogin.net, which gave him an alert saying a newer firmware is available, which downloaded and installed without issue.
Aydo
Jun 16, 2019Tutor
- CrimpOnJun 16, 2019Guru - Experienced User
Sad, sad, sad. Technology is complicated enough without our tools being unreliable.
- SoccerphysioJun 16, 2019Aspirant
So did you just go to the Orbi website and login, and then the firmware can be updated from the website, or is there more technical stuff involved?
