PeterJuett
Feb 01, 2020Aspirant
Orbi firmware incorrect
We've been having internet dropouts on connections through our RBR50/RBS50 system which has worked fine for several years until recently.. Connections through the RBR50 seem ok but connections throug...
- Feb 01, 2020
If you have the RBS latest v2.5.1.8 on your PC. Wire connect your PC to the back of the RBS. Press the reset button for 15 seconds then release. Wait about 5 minutes. Use IE11 or FireFox or Opera and navigate to 192.168.1.250. Use admin and password to log in. Use the RBSs web page to send the FW file to the RBS directly. Once sent, let it process. You can check to see if it updated by logging bacck in again. After checking the version, log out. Disconnect the PC from the RBS. Re-sync the RBS to the RBR.
If the RBR needs to be updated, update the RBR to v2.5.1.8.
PeterJuett wrote:Good point Tom. I've downloaded RBS50-V2.2.1.212 and RBS50-V2.3.5.30. never images upload without the 401 error.
CrimpOn
Feb 01, 2020Guru - Experienced User
Did you perform the manual update by connecting directly to the satellite (using its IP address)?
PeterJuett
Tried accessing the Satellite (192:168:0:4) but couldnt open Web based console. Is there another way in? One thing I noticed the Router status shows the Satellite is wired but the ethernet between Router and remote is not connected. The backhaul status is good.
- tomschmidtFeb 01, 2020Virtuoso
Make sure you are installing the RBS image file on the satellite, not the RBR image file (which is for the router).
- PeterJuettFeb 01, 2020Aspirant
- FURRYe38Feb 01, 2020Guru - Experienced User
followed the guide in the Users Manual to manually update the Satellite but the only response I get from the unit is:
<html><head><meta http-equiv='Pragma' content='no-cache'><meta http-equiv='Cache-Control' content='no-cache'><title> 401 Authorization</title>
<script language="javascript" type="text/javascript">
function cancelevent()
top.location.href='/unauth.cgi';
</script>
</head><body onload=cancelevent()></body></html>
