PeterJuett
Jan 31, 2020Aspirant
Orbi firmware incorrect
We've been having internet dropouts on connections through our RBR50/RBS50 system which has worked fine for several years until recently.. Connections through the RBR50 seem ok but connections throug...
- Feb 01, 2020
If you have the RBS latest v2.5.1.8 on your PC. Wire connect your PC to the back of the RBS. Press the reset button for 15 seconds then release. Wait about 5 minutes. Use IE11 or FireFox or Opera and navigate to 192.168.1.250. Use admin and password to log in. Use the RBSs web page to send the FW file to the RBS directly. Once sent, let it process. You can check to see if it updated by logging bacck in again. After checking the version, log out. Disconnect the PC from the RBS. Re-sync the RBS to the RBR.
If the RBR needs to be updated, update the RBR to v2.5.1.8.
PeterJuett wrote:Good point Tom. I've downloaded RBS50-V2.2.1.212 and RBS50-V2.3.5.30. never images upload without the 401 error.
PeterJuett
Feb 02, 2020Aspirant
Thanks FURRYe38, That worked a treat!
- FURRYe38Feb 02, 2020Guru - Experienced User
Enjoy. :smileywink:
