Blay
Jan 29, 2020Tutor
Orbi Firmware issue
Just got off the telephone with Spectrum technical support. Last night they found the latest firmware release for Orbi is preventing live streaming from working on their Roku app. They said the iss...
Dslo
Feb 07, 2020Aspirant
Add me to the list of angry customers. How can I not have the ability to disable the Armor/Bitfinder protection?! Just opens up a browser to renew subscription. All of my TV viewing is done through the Spectrum app.
I will never buy Netgear equipment in the future.
- FURRYe38Feb 07, 2020Guru - Experienced User
Factory reset your RBR and setup from scratch. Then don't enable Armor when presented with the enable or not.
Good Luck.
Dslo wrote:Add me to the list of angry customers. How can I not have the ability to disable the Armor/Bitfinder protection?! Just opens up a browser to renew subscription. All of my TV viewing is done through the Spectrum app.
- Wedge80Feb 11, 2020Aspirant
Factory reset fixed the issue. However, I still believe that Spectrum changed something as I hadn't done a firmware update or made any changes on the Orbi in months and the Armor trial had been expired for months as well.
- FURRYe38Feb 11, 2020Guru - Experienced User
Thanks for letting us know. Enjoy. :smileywink:
Wedge80 wrote:Factory reset fixed the issue. However, I still believe that Spectrum changed something as I hadn't done a firmware update or made any changes on the Orbi in months and the Armor trial had been expired for months as well.
- jkandcrewFeb 11, 2020Initiate
I reset my Orbi to factory settings then reinstalled it via the Orbi app just as I did the day I received it. It offered a free trial of Armor and I declined. Spectrum app has been working for almost an hour without freezing. Had to be the Armor security causing it. Just so happened the Spectrum app started freezing around the time the original "free trial" expired.
Joey
Glad the reset and not enabling Armor fixed it for you. Yes we have been seeing issues with Armor and people using it. Thankfully a reset and not enabling Armor seems to be the fix for most.
Enjoy. :smileywink:
jkandcrew wrote:I reset my Orbi to factory settings then reinstalled it via the Orbi app just as I did the day I received it. It offered a free trial of Armor and I declined. Spectrum app has been working for almost an hour without freezing. Had to be the Armor security causing it. Just so happened the Spectrum app started freezing around the time the original "free trial" expired.
Joey
