futureformerlaw
Aug 04, 2020Follower
Orbi Firmware Not Updating to 2.5.1.16
First issue I've had with my Orbi. For some reason, the Wifi has been dropping for the last two weeks....usually for 15-20 seconds at a time. So I figure now might be a good time for an upgrade from ...
Aug 04, 2020Guru - Experienced User
What happens if you download v16 FW files and manually apply them using a wired PC and web browser?
Update the RBS first then RBR lastly.
euidhawiojp12
Aug 19, 2020Aspirant
I've got an RBK22. Satellite backhaul syncing was a minor problem for me in earlier versions, and has been fixed by 2.5.1.16.
In earlier versions, my reboot sequence was this:
Satellite flashes white, then turns solid blue, then turns solid magenta, then turns solid blue again. Checking the web interface, the satellite had a poor connection on 2.4 GHz, then lost its connection, then regained its connection.
Eventually it would stabilize and work fine, with a 5GHz connection marked "Good," but it took about 10 minutes before the satellite was fully up and functional.
Now, a satellite reboot is up in about a minute, with a "Good" 5 GHz connection.
