t3t0r's avatar
t3t0r
Follower
Aug 14, 2019
Orbi firmware RBS50-V2.3.5.30 is Trash
I've been having so much trouble since Orbi firmware RBK50 V2.3.5.30 came out.... I was getting upset, blaming my ISP. I was losing packets constantly, got timeout when trying to open UNC path (file shares) from my computer, until I plugged straight to the modem and noticed the issue was not my ISP. Then, thought it was firewall or Antivirus, so I started testing one by one, disabled firewall on both ends, disabled AV and still had the same results, packets lost. Then I remember a **while back** I had a similar experience with Firmware RBK50 V2.2.1.210... so I decided to go back a couple of firmware version back, I went back from RBK50 V2.3.5.30 -to- V2.3.1.60 and all my problems were corrected.
1 Reply
  • Retired_Member's avatar
    Retired_Member
    So why did you upgrade to V2.3.5.30?
