ChuckinJapan
Mar 19, 2017Star
Orbi firmware status
I was having trouble with my Orbi dropping a wifi connection and then failing to sync with it's satellite when restarted. I just had a firmware update download while checking on my Orbi via my iP...
- Mar 19, 2017
You must use your personal username and password for your Orbi, the username is "admin" all lowercase however the password is what you setup when configuring your Orbi, it has nothing to do with the NetGear community or website, the router page is hosted in your home inside the Orbi.
Ely
Mar 19, 2017Luminary
ChuckinJapan
Mar 20, 2017Star
Ely,
Thanks again. That opened a whole new level of detailed information and control of my base station and satellite. I hadn't accessed the admin settings as it hadn't been necessary at during the initial set up, and would have stumbled around quite a bit longer without your help.
- ElyMar 20, 2017Luminary
ChuckinJapan my pleasure, glad I could help.
