sherveyjeff
Jun 15, 2017Apprentice
ORBI Firmware suggestions
Running latest firmware - new Orbi owner as of 1 week ago. Some obvious firmware/web console info needed. In the main router console - for connected devices - list if it is connected to satellite ...
peteytesting
Jun 16, 2017Hero
hi
what size house do you have ads the router and sat should be far enough apart that the client will roam from one to the other as you move through the house , too much overlap and your client has no reason to move on its own
if you open the sat/s via their ip address you will see what is connected to each sat , currently the router shows all devices connected
pete
sherveyjeff
Jun 16, 2017Apprentice
I have a 2300 sq ft house. Router is on 2nd floor in corner bedroom. Sat is on 1st floor on oppisite side of house in great room that is all open - 12ft vaulted ceiling. Yup - my 10.0.0.1 is my main router console, 10.0.0.16 is my Sat console where I can see Sat connected devices. Just more user friendly if data from all connected devices is all available from one main router console window.
Sometimes I find that If I monitor wifi speed on my laptop like at my basement desk docking station - that if it's under 100Mbps (bounces around from 60-140). I can disconnect from my SID and wait 5 secs and reconnect - and will be back at 300Mbps. In basement I should be connected to my Sat on 1st floor... but lots of times it is connected to 2nd floor ORBI router - puzzling.
- peteytestingJun 16, 2017Hero
2300sqft is pretty small and could be why there is too much overlap and the clients not roaming correctly , turn the sat off and do some tests with the orbi router on its own and see what the coverage is like
TBH its one potential flaw in all these mesh and DW systems has and thats users installing them in too small an area as if the overlap is to great then the will not perform as they should , if you cant get good coverage from a standard wireless AC router in such a small area then there are other experimental factors at play that will prob effect any wireless transmission including mesh and DW systems
