RonRolfsen
Oct 24, 2019Guide
Orbi Firmware update 2.5.0.38 problems
Have a 2 year old RBR50 with 2 satellites - have had no problems until recent update to 2.5.0.38. Everything is working howerever the GUI now has issues when attempting to display devices. The web ...
- Nov 02, 2019
The reset and setup from scratch on the RBR will probably fix the issues your seeing. Try then when your ready.
RonRolfsen wrote:After several reboots still have the problems (no Main page, no devices attached). I wanted to downgrade to 2.5.0.30 but now when I go to the Advanced-Administration-Firmware Update in the web gui get the:
400 Bad Request
This server does not support the operation requested by your client.
Mobile app does not allow a firmware downgrade as far as I can tell.
Is there a way to telnet into the router and downgrade the firmware?
(have not yet tried reset - saving as last resort since things are 'working')
Oct 24, 2019Guru - Experienced User
What browser are you using?
Happens with different PCs and browsers?
Be sure to clear out ALL browser caches before navigating to the RBRs web page.
Has a factory reset and setup from scratch been performed since the udpate?
UI has been working fine for me since installation. Safari, Opera and IE11. Mac And windows. Heading towards 3 days of up time. Been accessing the UI various times though out the days. I don't use Chrome.
Drtiny wrote:
Mines the same, worked fine for a day after firmware now web ui is broken
