RonRolfsen
Oct 24, 2019Guide
Orbi Firmware update 2.5.0.38 problems
Have a 2 year old RBR50 with 2 satellites - have had no problems until recent update to 2.5.0.38. Everything is working howerever the GUI now has issues when attempting to display devices. The web ...
- Nov 02, 2019
The reset and setup from scratch on the RBR will probably fix the issues your seeing. Try then when your ready.
RonRolfsen wrote:After several reboots still have the problems (no Main page, no devices attached). I wanted to downgrade to 2.5.0.30 but now when I go to the Advanced-Administration-Firmware Update in the web gui get the:
400 Bad Request
This server does not support the operation requested by your client.
Mobile app does not allow a firmware downgrade as far as I can tell.
Is there a way to telnet into the router and downgrade the firmware?
(have not yet tried reset - saving as last resort since things are 'working')
StevenKY
Oct 25, 2019Initiate
I updated to the new firmware (v2.5.0.38) a couple of days ago and since then I feel my satellite router is not picking up devices correctly. I have my two routers on opposite sides of my main floor. If I stand right next to my satellite with my iPhone then I can see my phone as one of the devices. However, I move into the kitchen (same side of the house and less than ten feet from the satellite and only going through one wall) then I do not see my phone as one of it's devices. The phone connectors to the main router on the other side of the house (through a wall and a stone fireplace). Needless to say when I do a speed test it is less than a quarter of the speed to my house.
- CrimpOnOct 25, 2019Guru - Experienced User
StevenKY wrote:If I stand right next to my satellite with my iPhone then I can see my phone as one of the devices. However, I move into the kitchen (same side of the house and less than ten feet from the satellite and only going through one wall) then I do not see my phone as one of it's devices.
Do you have "Fast Roaming" enabled? On the Orbi web interface, Advanced Tab->Advanced Setup->Wireless Settings, at the very bottom of the screen.
- AnonymousOct 26, 2019
StevenKY wrote:I updated to the new firmware (v2.5.0.38) a couple of days ago ....
WHY???
