RonRolfsen
Oct 24, 2019Guide
Orbi Firmware update 2.5.0.38 problems
Have a 2 year old RBR50 with 2 satellites - have had no problems until recent update to 2.5.0.38. Everything is working howerever the GUI now has issues when attempting to display devices. The web ...
- Nov 02, 2019
The reset and setup from scratch on the RBR will probably fix the issues your seeing. Try then when your ready.
RonRolfsen wrote:After several reboots still have the problems (no Main page, no devices attached). I wanted to downgrade to 2.5.0.30 but now when I go to the Advanced-Administration-Firmware Update in the web gui get the:
400 Bad Request
This server does not support the operation requested by your client.
Mobile app does not allow a firmware downgrade as far as I can tell.
Is there a way to telnet into the router and downgrade the firmware?
(have not yet tried reset - saving as last resort since things are 'working')
toe
Nov 02, 2019Apprentice
Stop telling people to factory reset. It’s a waste of time.
Nov 02, 2019Guru - Experienced User
Please stop telling users what to post. I'll post as I see fit. Factory resets are not required however a suggestion that does work. Others have had no issues with v38. IF your not willing to try it then don't. Up to you.
- Retired_MemberNov 02, 2019
FURRYe38 wrote:Please stop telling users what to post. I'll post as I see fit. Factory resets are not required however a suggestion that does work. Others have had no issues with v38. IF your not willing to try it then don't. Up to you.
toe wrote:
Stop telling people to factory reset. It’s a waste of time.Wow. Now that’s not helpful
