RonRolfsen
Oct 24, 2019Guide
Orbi Firmware update 2.5.0.38 problems
Have a 2 year old RBR50 with 2 satellites - have had no problems until recent update to 2.5.0.38. Everything is working howerever the GUI now has issues when attempting to display devices. The web ...
- Nov 02, 2019
The reset and setup from scratch on the RBR will probably fix the issues your seeing. Try then when your ready.
RonRolfsen wrote:After several reboots still have the problems (no Main page, no devices attached). I wanted to downgrade to 2.5.0.30 but now when I go to the Advanced-Administration-Firmware Update in the web gui get the:
400 Bad Request
This server does not support the operation requested by your client.
Mobile app does not allow a firmware downgrade as far as I can tell.
Is there a way to telnet into the router and downgrade the firmware?
(have not yet tried reset - saving as last resort since things are 'working')
dancar
Nov 14, 2019Aspirant
I have the same naming problem, and I have 40 devices. I do not want to reset and start all over. I even downloaded v.40 thinking that would be a fix, but it was not. Does anyone know if this problem will be fixed by Netgear and when? Thanks.
Nov 14, 2019Guru - Experienced User
A factory reset and setup from scratch should be performed as a last resort to see if this resolves what your seeing.
If you reset and setup and it fixes your problem besure to do a backup configuration to file for safe keeping. Saves time when resets maybe needed.
You can down grade FW as well.
dancar wrote:I have the same naming problem, and I have 40 devices. I do not want to reset and start all over. I even downloaded v.40 thinking that would be a fix, but it was not. Does anyone know if this problem will be fixed by Netgear and when? Thanks.
