RonRolfsen
Oct 24, 2019Guide
Orbi Firmware update 2.5.0.38 problems
Have a 2 year old RBR50 with 2 satellites - have had no problems until recent update to 2.5.0.38. Everything is working howerever the GUI now has issues when attempting to display devices. The web ...
- Nov 02, 2019
The reset and setup from scratch on the RBR will probably fix the issues your seeing. Try then when your ready.
RonRolfsen wrote:After several reboots still have the problems (no Main page, no devices attached). I wanted to downgrade to 2.5.0.30 but now when I go to the Advanced-Administration-Firmware Update in the web gui get the:
400 Bad Request
This server does not support the operation requested by your client.
Mobile app does not allow a firmware downgrade as far as I can tell.
Is there a way to telnet into the router and downgrade the firmware?
(have not yet tried reset - saving as last resort since things are 'working')
Wire1852
Nov 26, 2019Apprentice
Why isn't this message posted as a pinned announcement at the top of the Orbi Web page instead of a reply in a 3 page thread.
It's not rocket science.
Blanca_O wrote:Hi Orbi Community,
Please be informed that firmware v2.5.0.38 and v2.5.0.40 were pulled out from the update server.
The newly released firmware v2.3.5.34 fixes the web SSL certificate (https). If you are having issues with firmware 2.5.0.38/40, please downgrade the firmware to 2.3.5.30 or apply firmware 2.3.5.34. Please see download links:
RBR50 / RBS50 Firmware Version 2.3.5.34 - Hot Fix
https://kb.netgear.com/000061420/RBR50-RBS50-Firmware-Version-2-3-5-34-Hot-Fix
RBR50 / RBS50 Firmware Version 2.3.5.30
https://kb.netgear.com/000061080/RBR50-RBS50-Firmware-Version-2-3-5-30
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
https://kb.netgear.com/31573/
A new firmware will be available soon in replace with the firmware v38.
Blanca
Community Team
spinkick
Nov 27, 2019Apprentice
Why are they having such a hard time with firmware and this product? Its been 3-4 years since this device was released.
