RonRolfsen
Oct 24, 2019Guide
Orbi Firmware update 2.5.0.38 problems
Have a 2 year old RBR50 with 2 satellites - have had no problems until recent update to 2.5.0.38. Everything is working howerever the GUI now has issues when attempting to display devices. The web ...
- Nov 02, 2019
The reset and setup from scratch on the RBR will probably fix the issues your seeing. Try then when your ready.
RonRolfsen wrote:After several reboots still have the problems (no Main page, no devices attached). I wanted to downgrade to 2.5.0.30 but now when I go to the Advanced-Administration-Firmware Update in the web gui get the:
400 Bad Request
This server does not support the operation requested by your client.
Mobile app does not allow a firmware downgrade as far as I can tell.
Is there a way to telnet into the router and downgrade the firmware?
(have not yet tried reset - saving as last resort since things are 'working')
Blanca_O
Nov 25, 2019NETGEAR Employee Retired
Hi Orbi Community,
Please be informed that firmware v2.5.0.38 and v2.5.0.40 were pulled out from the update server.
The newly released firmware v2.3.5.34 fixes the web SSL certificate (https). If you are having issues with firmware 2.5.0.38/40, please downgrade the firmware to 2.3.5.30 or apply firmware 2.3.5.34. Please see download links:
RBR50 / RBS50 Firmware Version 2.3.5.34 - Hot Fix
https://kb.netgear.com/000061420/RBR50-RBS50-Firmware-Version-2-3-5-34-Hot-Fix
RBR50 / RBS50 Firmware Version 2.3.5.30
https://kb.netgear.com/000061080/RBR50-RBS50-Firmware-Version-2-3-5-30
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
https://kb.netgear.com/31573/
A new firmware will be available soon in replace with the firmware v38.
Blanca
Community Team
Vaslo
Nov 29, 2019Guide
Blanca_O wrote:Hi Orbi Community,
Blanca
Community Team
Yay, about time. One of the executives must have finally had some problems because giving the "Just Completely Reset Your Router" and "No one else is having this problem" finally caught up to the decision makers. What possibly took so long to make this change?
EDIT: I realized I STILL have issues with v30 - thats what I have installed after my last complaint and it's the same problem. I gave up for a few weeks hoping Netgear would get it together.
Some guy on Slickdeals said the following: "I went to v2.2.1.210 and its resolved my issues with Apple Products. I've turned off auto-updates and its been working normally for a week now." Going to try this one. I hadn't updated the firmware in a while so was using one that was likely before this one.
