MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
espcar
Oct 22, 2019Star
Release Notes:
- tkrdhdNov 18, 2019Guide
Except it doesn't enhance the device recognition mechanism of the attached devices list. It completey screws them all up, randomly assigns mismatching device icons, and doesnt allow you to change/update them. It also will now only assign 1 or 2 out of 27 devices to my Satellite and had devices like Nest cameras that require high broadband assigned to 2.4g instead of 5g. Then they wont even let you contact them find a fix! I can't use my iphone now in my bedroom with my satellite 15ft away in the same room (no walls) and router directly across the hall!
- FURRYe38Nov 19, 2019Guru - Experienced User
Have you tried v40 FW update. A few others have said this has fixed there device naming issue. Something to try. I would factory reset the the RBS and RBR and setup from scratch and see if this works for you. If not, revert back to v30.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
tkrdhd wrote:Except it doesn't enhance the device recognition mechanism of the attached devices list. It completey screws them all up, randomly assigns mismatching device icons, and doesnt allow you to change/update them. It also will now only assign 1 or 2 out of 27 devices to my Satellite and had devices like Nest cameras that require high broadband assigned to 2.4g instead of 5g. Then they wont even let you contact them find a fix! I can't use my iphone now in my bedroom with my satellite 15ft away in the same room (no walls) and router directly across the hall!
- Retired_MemberNov 19, 2019
tkrdhd wrote:................. I can't use my iphone now in my bedroom with my satellite 15ft away in the same room (no walls) and router directly across the hall!
wow....you do know that unless you live n the moon, you can shift your iphone over to the celluar tower transmission while you trouble shoot your Orbi? :smileyhappy:
- tkrdhdNov 20, 2019GuideRetired_Member It’s been over a month and they’ve done nothing. There’s no troubleshooting to be done...this all became an issue when the router automatically updated to this new **bleep**ty, untested buggy FW. I didn’t spend $350 on a router system only to have to burn thru my data on my phone plan. I don’t mean to be an ss, but that’s just a stupid response. Why are you so hard up to place blame everywhere but where it’s due? NG got their money and now they simply don’t give a **bleep**.
