MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
 Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
TedSz
Oct 23, 2019Initiate
This firmware update has destroyed all my Device List name and icon configuration. It creates a new device list with cryptic names that may include device network names, and names with portions of the device's MAC address. If you try to edit the names and icons, it resets them. There are new icons.
- MikeG63Oct 23, 2019Apprentice
Ditto for me, but I can't edit and apply any subsequent changes. It wasn't quite as extreme for me as the experience you describe. Only some were 'randomly' changed. Also I got the 'new' icons which may be deliberate as part of th the new firmware upgrade.
- Licorice1978Oct 23, 2019Initiate
And the setting for different SSID has been gone and can't be set again.
So 6 bugs fixed, 2 new ones and counting :smileylol:
Also wrt - [New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
Hmmmmmm......did something there to break it as well!!!
 - RaymonddenietOct 23, 2019Guide
As well for me it changed my settings in the portal and on the iOS apps.
When I try to change it, it will only stand until a restart of the app.Some other divices get a name not even close to what it is.
I hope Netgear will fix this soon.
- FURRYe38Oct 23, 2019Guru - Experienced User
Naming of devices and saving changes is confirmed:
Please contact NG support and let them know about it.
 - LSStreamOct 23, 2019Guide
I concur with this. Most of my network attached devices custom names/attributes have been replaced by what appears to be a sub-par attempt at Netgear to automatically determine what a given device is. Sure, good luck with that effort, but at least give us the option to use our own naming convention, so we aren't subject to what your software thinks it should be.
It's just a new bug with the new detection feature. NG is aware of it and hopefully will fix it.
Please be patient.
LSStream wrote:I concur with this. Most of my network attached devices custom names/attributes have been replaced by what appears to be a sub-par attempt at Netgear to automatically determine what a given device is. Sure, good luck with that effort, but at least give us the option to use our own naming convention, so we aren't subject to what your software thinks it should be.
 - kuno2501Nov 24, 2019Guide
Having same issue since the latest update Router Firmware Version V2.5.0.38
Attached device name got messed up and cannot rename some of them, also cannot change access control of some of the attached devices!!
This update is terrible- FURRYe38Nov 25, 2019Guru - Experienced User
Give v40 a try and see if this resolves this for you. Others have reported v40 fixed it for them:
I recommend doing a factory reset and setup from scratch on the RBR after updating FW. If this doesn't work for you, revert back to v30.
kuno2501 wrote:Having same issue since the latest update Router Firmware Version V2.5.0.38
