MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
TedSz
Oct 23, 2019Initiate
This firmware update has destroyed all my Device List name and icon configuration. It creates a new device list with cryptic names that may include device network names, and names with portions of the device's MAC address. If you try to edit the names and icons, it resets them. There are new icons.
Raymonddeniet
Oct 23, 2019Guide
As well for me it changed my settings in the portal and on the iOS apps.
When I try to change it, it will only stand until a restart of the app.
Some other divices get a name not even close to what it is.
I hope Netgear will fix this soon.
- FURRYe38Oct 23, 2019Guru - Experienced User
Naming of devices and saving changes is confirmed:
Please contact NG support and let them know about it.
