MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
 Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
chingwa14
Oct 23, 2019Initiate
Same here... Updated and took about 10 mins at best, but a slew of issues popped up!
First was the SSIDs... I had them changed manually via Telnet to indicate 2.4 GHz vs. 5.0 GHz's SSIDs... After the update, the 5.0 GHz SSID came in and out and a third one popped up as well. Tried manually correcting the SSIDs and rebooting the router... worked for 10 mins... and then the issue repeats. Tried like 5 times and each time with the same result. Since you don't let us change it within the router's GUI/website, this was the only way via Telnet. Now your firmware overrides this somehow? Really Netgear???
Also, I've noticed things really weird with my connect. Videos at the beginning have a hard time buffering initially, and just not smooth like normal as before the update. Is there a way to backtrack and use the previoius firmware?
Then... the new icons and names for device is a nice touch... but some of the devices cannot be changed for some reason... Tried via the router GUI/website... chagned for 30 seconds... then reverts. Tried via the Orbi app... same result.
Fixing this via an subsequent update will take a while form Netgear... and I don't think we should be subjected to sub-par performance on a unit that many people forked out over $400 for... We really didn't spend this amount to have these issues that we would have compared to other routers...
Netgear... please help... please help ASAP!!!
CrimpOn
Oct 23, 2019Guru - Experienced User
My guess is that you can do a "Manual" firmware install to go back to 2.3.5.30. Just download the files for router and satellite from the Netgear support web site: https://www.netgear.com/support/product/RBR50.aspx#download Do the satellite first by connecting directly to the satellite's web interface, then do the router last.
