MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
chingwa14
Oct 24, 2019Initiate
You're able to "Manually" sets up the two SSIDs that designate the two bands... (2.4 and 5.0 GHz) via loggin into the router settings via Telnet.
Giving the router a few commands to rename the wl_ssid (2.4 GHz) and wla_ssid (5.0 GHz) will allow the router to broadcast their individual bands via the SSID you designate.
But after this update, it seems like Negear took the liberty to force the existing labeling to be removed, and utilize some type of mysterious convention to take your exisitng 2.4 GHz name, and just take like the first 4-6 characters to name the 5.0 GHz... which is completely bizzare...
With the naming of the devices completely haywired... I've lost granularity on my devices... and now have to make a separate list on all of their MAC addresses to ensure I can rename them in the future WHEN Netgear will offer an update to correct this issue...
Oct 24, 2019Guru - Experienced User
NG is aware of the naming issue.
Please be patient while they work on it.
