MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
 Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Oct 24, 2019Guru - Experienced User
porlockweir wrote:Installed this update yesterday, and then spent the next 6 hours attempting to have a workable network, factory resetting twice in the process. Issues are:
- Random blocking of devices when access control is switched on – including at times Orbi satellites. This includes devices being blocked while attempting to carry out actions on the web interface (e.g. it let me log in but then blocked the device I was using when I went to the factory reset page) and reblocking devices 5 min after being added to allowed list.
 Have you set IP address reservations for each device you are attempting to control BEFORE you engage any access controlls?
- Internet connection constantly dropping out until factory reset for a second time
 What is the MFr and model# of the ISP modem/ONT your using with the RBR?
Something I haven't seen yet with mine connected to a C7800 thats in modem only mode. No drops.
- Web interface not functioning properly, e.g. the button to confirm factory reset would not work
 I'm using Opera and have not see any issues with the RBR or RBS web page. Be sure to clear out ALL browser caches before going to the web pages.
- The renaming issue that others have experienced
 NG is aware of this, Please be patient.
This is the worst update I have experienced to date (and this is my third fourth Netgear router), and totally unacceptable. I know some recommend a factory reset every time you update, but why should we have to spend time reinputting settings every time?
Its only recommended if you experience issue after any update. There are configurations that may become problematic as new FW comes out. So to check this, a reset is needed to see if the problems still continue or not. Some have been able to update with out. Some have had to. I just make it a habit to reset after loading and setup from scratch. My choice.
System Uptime 02:18:45:09
porlockweir
Oct 24, 2019Guide
Yes, and had to reinput twice before giving up and disabling access control until bug is fixed
I'm using a Netgear DM200 - the second factory reset seems to have resolved this
Did that, and tried a different browser. Was also taking 5+min to load a page before second factory reset. Fortunately has not reoccured since I was ready to throw it out the window at well past midnight last night, having done the update at 6pm.
 NG is aware of this, Please be patient. Only noted for confirmation to others.
Don't disgaree, but when you are having to reinput IP reservations etc it is really rather annoying to have to keep doing so.
- FURRYe38Oct 24, 2019Guru - Experienced User
'I'm using a Netgear DM200 - the second factory reset seems to have resolved this"
Is this modem in router or bridge mode? It should be bridged or running modem mode only. If not, this would be one reason why the Orbi could be having problems.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYa I know about peoples configurations. However backup configurations to file can help here. First we need to get the modem and RBR setup and stable first. Lets leave IP reservations and access controls alone for now. Disabled. One step at a time.
- thedakOct 25, 2019Apprentice
2.5.0.38 is the worst firmware my devices have ever seen. I have a RBK50 with two RBS50s and they have been functioning perfectly for over two years. Did the upgrade last night and multiple problems. (1) Attached devices naming, icons, and types are wrong and manual correction doesn't stick, (2) my Galaxy S10+ which normall connects at 5Ghz over 400Mbps struggled to maintain a 2.4 connection at abysmal speeds (< 40 Mbps) link speeds. This is without any geographic changes. Rebooted all and no help.
Downgraded back to 2.3.5.30 and everything worked perfectly again.
Not sure this firmware is ready for full production deployment. Recommend it be PULLED due to the plethora of problems are fixed.
PS: My RBK50 is in AP mode.
- FURRYe38Oct 25, 2019Guru - Experienced User
Has a reset and setup from scratch been performed since the update?
Others are having no problems including me:
Theres only one issue that NG is aware of that deal with the custome naming of the devices. Not a show stopper.
thedak wrote:2.5.0.38 is the worst firmware my devices have ever seen. I have a RBK50 with two RBS50s and they have been functioning perfectly for over two years. Did the upgrade last night and multiple problems. (1) Attached devices naming, icons, and types are wrong and manual correction doesn't stick, (2) my Galaxy S10+ which normall connects at 5Ghz over 400Mbps struggled to maintain a 2.4 connection at abysmal speeds (< 40 Mbps) link speeds. This is without any geographic changes. Rebooted all and no help.
 - porlockweirOct 30, 2019Guide
FURRYe38 wrote:'I'm using a Netgear DM200 - the second factory reset seems to have resolved this"
It's in bridge mode, always has been, has never been set up as a router as was brought alongside the Orbi.
Modem Combo Units:
Couple of options,
I tried loading a back-up, first, still had lots of problems. I really don’t understand why anyone would think having to Factory reset your device every time there is an update is ok? It’s not.
Also now have new bug – it disconnects from the internet every time a new device is added and has to be rebooted to reconnect.
- FURRYe38Oct 30, 2019Guru - Experienced User
So a 2nd factory reset resolved your problems you were seeing?
i agree that users shouldn't have too, however for these odd issues seen after a FW udpate, it maybe needed. I'd do another backup configuration to file after the reset and setup from scratch. So you have good clean backup.
Enjoy.
Modem Combo Units:
Couple of options,
