MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Oct 30, 2019Guru - Experienced User
Navigate to the RBRs web page and select Advaced tab/Administration/Backup Settings. Click on the back up button. This generates a backup file. Move this to a safe place.
dnonnema wrote:I bought mine in Sept, and had massive connectivity problems until a NG tech advised me to upgrade the FW. once that was accomlished, all was good.
I was hesitant to upgrade again, but I upgraded to 2.5.0.38 last week without any problems.
Question how do I back up the configuration? I have a feeling I will need to jump through hoops with the next FW update.
mtowle
Oct 30, 2019Tutor
One other thing I noticed is my phone updated its firmware to iOS 13.2 very recently, so there are two variables here (iOS and Orbi firmware updates). I did a "forget this network" on my phone and then joined again. I'll update this post in a couple days to let everyone know if that solved the issue or if it's still occurring. I'll also take a look at my wife's iPhone to see if it's having the same problem and what firmware version it's running. Thanks.
- FURRYe38Oct 30, 2019Guru - Experienced User
mtowle wrote:One other thing I noticed is my phone updated its firmware to iOS 13.2 very recently, so there are two variables here (iOS and Orbi firmware updates). I did a "forget this network" on my phone and then joined again. I'll update this post in a couple days to let everyone know if that solved the issue or if it's still occurring. I'll also take a look at my wife's iPhone to see if it's having the same problem and what firmware version it's running. Thanks.
I updated to iOS 13.2 as well. I haven't see to many issues. Mostly with other applications and devices I have with other Mfrs.
