MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Raymonddeniet
Oct 30, 2019Guide
Is there a way to downgrade FW to the previous version and wait until there will be a fix?
Waiting for the next FW upgrade, will that solve the problem?
webbo73
Nov 01, 2019Initiate
I had the same problems as others have posted in this thread, so downgraded back to 2.3 manually. I did the satellites first and then the router. Seems ok so far and connectivity back to how it was before.
- FURRYe38Nov 01, 2019Guru - Experienced User
Next time, try a factory reset on the RBR and RBS after upgrading FW if you see problems after a FW update as a last resort. Others have had good operation after a reset of the system.
Mine ran solid for over 5 days with out issues aside the device naming issue.
webbo73 wrote:I had the same problems as others have posted in this thread, so downgraded back to 2.3 manually. I did the satellites first and then the router. Seems ok so far and connectivity back to how it was before.
- Retired_MemberNov 01, 2019
FURRYe38 wrote:Next time, try a factory reset on the RBR and RBS after upgrading FW if you see problems after a FW update as a last resort. Others have had good operation after a reset of the system.
wow....I'm sure the OP hopes there is NO next time.
- BuffdaveNov 01, 2019Aspirant
This software bug or whatever the hell it is ruined my week. Last netgear router that I will buy.
