MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Retired_Member
Nov 02, 2019
bjornand1 wrote:My issue with the Orbis is that after iOS13, HomeKit has been extremely buggy, with devices constantly cycling between updating and no response, only occassionally actually working. When I saw Firmware Update 2.5.0.38 with fix for HomeKit issues, I truly hoped it would fix my problems (like an update a couple of years ago did), but if anything, there is only a slight improvement. Especially my iPhone will take forever to get an updated device status, with the iPad/Macs being somewhat faster.
Is there anything that can be tweaked on my end, or is the answer simply to get a different mesh system?
Try to revert back to an eariler firmware version
bjornand1
Nov 02, 2019Aspirant
Retired_Member That could be an option, would anyone know which FW version is stable with HomeKit?
- Retired_MemberNov 02, 2019
bjornand1 wrote:Retired_Member That could be an option, would anyone know which FW version is stable with HomeKit?
Think back to the last time your system was running OK. If not, it's a crap shoot, in going back. Good luck.
