MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Nixerr
Nov 01, 2019Aspirant
Having terrible connectivity problems since this FW upgrade as well as the device naming bug. Going to have to (reluctantly) reset orbi system according to this thread. Disappointed to say the least. Suggest that when updates are realised for the system that it should state 'Optional' together with a caveat notice. (Frustrated user)
Nov 02, 2019Guru - Experienced User
Have you tried a facory reset and setup from scratch? Others have v38 working:
Mine was solid for more than 5 days after updating and resetting. No issues other than the device naming issue.
Try a reset.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
Nixerr wrote:Having terrible connectivity problems since this FW upgrade as well as the device naming bug. Going to have to (reluctantly) reset orbi system according to this thread. Disappointed to say the least. Suggest that when updates are realised for the system that it should state 'Optional' together with a caveat notice. (Frustrated user)
