MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Nov 02, 2019Guru - Experienced User
I fully understand the frustration of setting up from a factory reset. Many users have different configurations. Once thru the reset, users have to remember that there is the backup configuration to file. This saves time after doing a reset. The reset help clear out any lingering prior FW and mis-configurations. There may some new FW code that makes older FW code or configurations incompatible, thus a reset is needed.
Factory reset is as last resort. however some users don't even give this a try. When users don't at least try this as a last resort and lest us know that they did, then it its frustrating for us, knowing that the reset has help us and others.
Try the reset and when you get the system setup. Do a Backup of the configuration to file. This is a time saver.
Retired_Member
Nov 02, 2019
Do you offer phone service?
