MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Alanandstaci
Nov 02, 2019Aspirant
Ever since i updated, I have had issues with my wifi slowing way down, almost to 10 or 15 when I normally get near 300. Then I have to reboot and it works for a while. Then it happens again. Please help I have the RBR50 V2
Retired_Member
Nov 03, 2019Roll your firmware back to an eariler version and stop doing manual updates.
- NixerrNov 03, 2019Aspirant
I searched downloads for my RBK50 v2 system and the only firmware available to download is the dreaded v2.5.0.38. Can you provide a link to previous versions? I performed a complete reset of my Orbi system (as suggested) and the results arent much better, in fact it seems that the wireless range is not as good as it was prior to this latest firmware update and I have encountered some wifi blackspots in my house again. I need to get this back to a workable state, thank you.
- Retired_MemberNov 03, 2019
If a earlier version is not available on the NG download area, I'm not sure where to look. Maybe other can chime in.
- thedakNov 03, 2019ApprenticeGo to the orbi (rbk50) download page and click on " previous versions.". They should all be there
