MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
agneev
Nov 05, 2019Aspirant
Any idea when the fix is coming? Been a while since the release of this buggy firmware.
- CrimpOnNov 05, 2019Guru - Experienced User
I have not detected a "pattern" in Orbi firmware updates. 2.3.5.30 came out in (May? June?). However, this one seems to have been such a "stinker" that a rework will show up sooner. However, MY GUESS is that it still could be months.
- MikeG63Nov 06, 2019Apprentice
So, here's the pragmatic thought - my router works fine, as do my satellites. So the 80 / 20 rule stands, i.e. does it fulfill 80% of my requirements. My network is stable and all my peripherals work fine with no drops and outages, so I ask myself why get stressed over some icons and names. Yes its annoying, inconvenient, not professional, bad QA, and more importantly for Netgear reputation damaging!!!
Absolutely a new firmware version will come along as per Netgear's release cycle, again probably not well QA'd, and may well address some of the issues / concerns and most likely introduce others. So I am keeping a healthy cynicism and from now on will adopt an n-1 approach.
- AnonymousNov 06, 2019
MikeG63 wrote:and while you're at it...STOP performing manual firmware updates....
