MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
tomschmidt
Nov 20, 2019Virtuoso
FURRYe38 wrote:A factory reset and setup from scratch should have been tried as a last resort when applying v40. A few have posted v40 seems to have solved the device naming issue. Thought this doesn't fix v38 as this is where the problem started and confirmed. If v40 doesn't work after a factroy reset and setup from scratch, users will need to revert back to v30 and wait for NG to fully fix this problem. NG doesn't post information on when new FW updates are forth coming. So users will need to keep an eye on the download page or here in the forums.
FURRYe38 , I did a factory reset when the upgrade to V2.5.0.38 devices were messed up and it did not help. I then upgraded to V2.5.0.40 and some devices were fixed, but others were then broken and I was unable to edit the devices. A factory reset between .38 and .40 minor releases should not be needed.
Nov 20, 2019Guru - Experienced User
Thanks for letting us know what you did.
