MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
kuno2501
Nov 24, 2019Guide
Having same issue since the latest update Router Firmware Version V2.5.0.38
Attached device name got messed up and cannot rename some of them, also cannot change access control of some of the attached devices!!
This update is terrible
Nov 25, 2019Guru - Experienced User
Give v40 a try and see if this resolves this for you. Others have reported v40 fixed it for them:
I recommend doing a factory reset and setup from scratch on the RBR after updating FW. If this doesn't work for you, revert back to v30.
kuno2501 wrote:Having same issue since the latest update Router Firmware Version V2.5.0.38
